Moving Rigid Groups
Moving Rigid Groups
jeph_s22
Moving Rigid Groups
jeph_s22
Hello everyone.
In the attached file, I would like to move this rigid group up, so less of the roller is inside the tube. I will also then have to extend the plates where the bearings are mounted but I think that should be easy.
I am not sure how to do this without disrupting other joints. Can any one assist me with this?
File attached.
jhackney1972
You did not say how far you want to move the roller assemblies up but I did it so the roller is above the tube.  If you need extra help understanding the process, just ask.  The bearing plates can be increased by going back to the original sketch, which is not constrained, and adding dimensions.  Model is attached.
Edit: You also did not mention what to do with the slots in the tube.
John Hackney, Retired
jhackney1972
You were not very clear on what you wanted to do with the bearing mounts.  I first thought you wanted to increase the size of the plate below the bearing but now I am thinking you need to extend them to match the new height of the assembly over the pipe.  I moved everything up 1.875 inches.  Modified model is attached.
jeph_s22
Thank you for your response. I apologize for not being clear in describing my issue.
I wanted to move it only about 1.10" higher, only so less roller protrudes into pipe.  Would you mind making a screencast showing how you did the move in the file you attached?
jhackney1972
Screencast is attached as well as the model with only 1.10 inches movement.  If this Screencast solves your question please do not forget to select "Accept Solution" to close and acknowledge the solution post.  If you have further questions please ask.
TrippyLighting
My suggestion would be to fix that yellow icon in your timeline and then apply whatever changes John has suggested.
