Moving construction lines?
JetForMe
JetForMe
A moment ago I was able to move construction lines in the plane without changing their orientation. Now I can't seem to do that. The Move command won't keep the line selected, nor let me select the line. What happened?
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
jeff_strater
Hi @JetForMe, can you post a screencast of this behavior.  It should work as you expect it to.  Move should be able to move any kind of sketch geometry , construction or otherwise.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
JetForMe
I'm not able to get the Autodesk screencast app to work (it just hangs after I finish a recording). Here's a movie: http://cl.ly/1w2u3a3B0f11
It's a little haphazard, but it shows both the move problem and my inability to create construction lines in a sketch.
NicolasXu
Thanks for the update, JetForMe.
I also explain the issue in your another thread. Hope it's clear. If you have any other questions, please feel free to post them on the forum. We're more than happy to provide support.
http://forums.autodesk.com/t5/design-validate-document/why-can-t-i-use-construction-lines-in-a-sketc...
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
