Moving Component Point to Point
colinNJB25
colinNJB25
I am having a silly problem and I can't figure out how to do something simple. I am inserting a component into a model from another file. I need the square face to match with the center of the square hole. I can easily select the center of the square face but when I show the center mark for the square hole I can't click on it. I can pick any of the other marks created by the square hole like the center of any edge. How do I select the center as my second point?
davebYYPCU
Hold the Control key down after hovering over the face, the square hole belongs to.
colinNJB25
On my Mac it's the command key. Thank you for that! It was driving me crazy.
HughesTooling
For a component you'd be better off using a joint. Move and save position are not efficient, lots of save positions in an assembly will hit performance. I avoid move so might be wrong but it's also not a paramentic move so modifying the target component will not update like it will with a joint.
Mark
Mark Hughes
Owner, Hughes Tooling
