Move tool issue
Move tool issue
marks3U6W9
Move tool issue
marks3U6W9
I find that whenever I select a component and then the move tool I’m unable to select points for the “point to point” functionality. If I select free move and move the component a little and then select the point to point option I then have no problems selecting the points. I’m running F360 on a Mac if that’s relevant.
Any ideas what I’m doing wrong or is this a known bug? Thanks
innovatenate
Autodesk Support
Autodesk Support
I just ran a quick test on MacOS 10.12.6, Fusion built 2.0.3481, and I was not able to reproduce in Direct Modeling or Parametric environment. Below is a link to a screencast of the attempt.
http://autode.sk/2xzjCjj
Perhaps you are not selecting the start and end point correctly? Can you record a screencast of what you're seeing?
Nathan Chandler
Principal Specialist
marks3U6W9
I think I worked out what I was doing wrong. Yes you're correct I wasn't selecting the start point correctly. Cheers
