Move sketch to follow a line
z.alexander616
z.alexander616
Hello all,
I am try to see if there is a way to Move/copy the circles and have them follow the curve of the part.
I have never used the screen cast before. Let me know if yall can access it fine.
g-andresen
1. what do you want to achieve
2. blue circles are sketch elements > the black line represents an edge of a body
Please share your file*
If your goal is a pattern of holes along a path, a hole would need to be created first and then duplicated.
günther
*File >Export > save as f3d on local device > attach to next post
davebYYPCU
Nope, in sketch mode, it’s manual placement,  and expect Fusion to choke on it.
In modelling mode, You would cut the plate with one circle,
the use Create > Pattern > Pattern on Path, > Feature, and select the Extrude Cut from the timeline,  Result may be unexpected.
Might help...
