Move in a sketch - Z axis
Mark.Lancaster
Consultant Consultant
Mark.Lancaster
I do apologize if this has been asked before..  I did a search and there were many search results regarding the move function in a sketch environment  (meaning it would take some time to go through each one)..  Smiley Very Happy   Also I've been away from Fusion 360 for quite some time  Smiley Sad and trying to get back into it.
May I ask what is the purpose of moving a 2D sketch in the "Z" axis?   It seems like when that occurs you can't really do anything with those "Z" coordinate entities.  Or am I missing something here?
Mark Lancaster
SaeedHamza
Hi Mark,
I personally use it a lot to get 2 profiles, the original and an offset, and that helps a lot especially in the loft command
but of course this is one of so many cases that moving along z-axis can be used in
Here are some pictures to help you understand what I mean
Regards
Saeed
Saeed Hamza
Mark.Lancaster
@SaeedHamza
Thanks..  After I posted I was kind of thinking of those items..   So use to Inventor interface and multiple sketches to do those type of things..
Mark Lancaster
SaeedHamza
I'm not used to Inventor to be honest, so I didn't understand the last part 😛
But I'm glad I could help
Best of luck
Saeed
Saeed Hamza
Mark.Lancaster
Sorry I meant in Inventor I would have to create multiple individual sketches to accomplish the same thing, whereas Fusion I could do all the sketches under a single sketch operation.  Thanks again for your help.
Mark Lancaster
