Move and copy multiple objects to multiple snap-to locations.
David-Cooper
Observer Observer
David-Cooper
Observer
Observer
When Move tool is selected and copy is checked only one item is selectable and only one target point is selectable.  I would like to be able to select multiple items and snap a copy to multiple target points.
whittakerdw
The rectangular pattern command may be of use for you. This can be found under the create tab, pattern, and rectangular pattern. I don't know if this will be of use to you as when using the rectangular pattern tool, all parts that are being copied are being spaced an even amount from one another. If this won't help, then the only other way I know of is to use the move/copy command and the more you copy, the more you can select and copy again when moving for a second and third time and so on.
