As far as I can tell there is no simple way to move something, let's say a point, to a specific position that does not require a calculator or some good in-head math.
I can move the pivot to the origin, but when I put say 2.0 into X and 2.2 into Y, it still moves the point 2 units X and 2.2 Y from where it was. I could create a new point at 2.0 X and 2.2 Y and move point to point, only now I have two points instead of one, which creates its own set of issues.
You can select a point and on screen it tells you where the point is. If you select Move and then select the point, why can't you offer a mode where 2.0 in X and 2.2 in Y (or whatever is entered) moves to that location?
Basically, if the object is at 1.0 X and 1.0 Y I can do the math on my little $2 calculator and enter 1.0 X and 1.2 Y and get where I want to go. But why not let us click on an option and have the computer do the math?
Laziness is not really the issue, it is time. This alone would speed a lot of my design work up a lot (particularly where I am recreating things from measurements). Someone help me out here!
