MOVE A FEATURE
MOVE A FEATURE
mickingaamco
MOVE A FEATURE
mickingaamco
Can Fusion 360 move a feature. For example, I have a slot in one place, and I want to move it from its current location to a new location. All of the modelers I have worked with in the past could do this,  but I don't see it in Fusion.
TrippyLighting
You can select the feature and use the move tool.
mickingaamco
Thank you. I actually figured it out right after making the post. It is not too bad. You just have to select the faces you want to move, then place the moving axes and move them.
