Mouse Cursor Position
Message 1 of 31
Is there a way you can bring up and see the mouse cursor co-ordinate?
Replies (30)
Message 21 of 31
chromvision
This video does not solve the problem.
When drawing scketch I often need to start line at certain position. It is very hard without knowing cursor coordinates!
Surprising arrogance from the developers - users requested this featire for over 5 years already. It sould be very simple to add togglable feature.
Message 22 of 31
TRIALCAD2014
Yes, the only correct solution is to display the coordinates the same way as ALL the other graphic design software does, as the previous user specified.
Message 23 of 31
mevans89MVW
I find it easiest to draw it in Eagle and import. Eagle is part of Fusion360 now.
I agree it's not the answer to the question though.
Message 24 of 31
fjrpilotnc
That is the prickiest solution.  Not solved.
Is a small X:xxx Y:yyy Z:zzz in the corner so hard?  The software obviously knows what I'm pointing at, just display it already.
Message 25 of 31
brucep.borer
Community Visitor
Community Visitor
I am evaluating Fusion 360 for my hobby use.  If it does not show cursor coordinates then I will not be able to use it.  If cursor coordinates are not available can I have cartesian coordinates instead of polar coordinates when drawing lines, etc.
Message 26 of 31
laughingcreek
selecting a sketch point show's it's position in the lower right corner.  if the point is not constrained to anything you can drag it around and the display keeps up with it's position.
Message 27 of 31
heinzight
I want to know xy of my cursor! Inventor had it and I miss it! Many time I want to draw an object 3 cm from another object. I have to draw a Line 30mm away, end Line, make it Nominal/Construction, then start my next object. Cursor coordinates is paramount!!
Message 28 of 31
geovolvoman
MS Paint has it
Illustrator has it even Better:
It's even contextual. When you move an object, it shows you where you're moving it to and how far etc:
So, if people who draw pretty pictures for a living can have it, why can't engineers who could actually seriously benefit from it???
Message 29 of 31
manoweb
Hello, just checking if in 2023 there is a way to show coordinates of points in a sketch. It's very important.
Message 30 of 31
crford8JTJW
Observer
Observer
Hey there, new Fusion user and was really surprised when I couldn't find the cursor coordinates anywhere on screen.  Is there still no way to enable this?
Message 31 of 31
johnQZV8B
Community Visitor
Community Visitor
Lets move this into 2025, I was searching because I could not believe it wasn't available! Back to counting grid marks I guess. If draging a point can display, then surely you can display before dragging the point?
Is there a use case where this is terrible? If that's the case, why can't we disable it for those cases, like if you declare the model a parametric one, the cursor position changes.
