Motion Study / Animation Render Button doesn't appear
Message 1 of 11
I have the issue that the motion render button doesn't appear after the video render operation.
I followed this guide (https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/how...) and also tried many other different things (different model, save and repopen, new motion study, different resolution of the video, etc) but cannot get it work.
Any help would be much appreciated.
Replies (10)
Message 2 of 11
rushabhthakkar_910
Can you share a Screencast Video and the File too..
File> Export> Save to Local Drive> and Attach it here..
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 11
jhackney1972
The main thing is to make sure your have created your Motion Study on the latest version of the model, older Motion Studies will not work.  Also, when you create your initial Render, it seems you must use Cloud rendering instead of Local Rendering.  There is a free version of this which is shown in the Screencast.  Once you have this rendering, you can setup your Motion Study Render.  You must use Cloud Rendering and it is rather expensive so make sure you render what you finally want.  The process is shown in the Screencast.
John Hackney, Retired
Message 4 of 11
Yes, I used the latest model. Even saved between every step. Tried to record a screencast, but that doesn't recognise the F360 and is just a blank desktop image.
I could share the file but doesn't really matter. Created a new project and file but the same outcome. Pretty lost...
Message 5 of 11
Here the blank sc
Message 6 of 11
"Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied."
Nothing works today... 😞
Message 7 of 11
jhackney1972
Saving between every step may be your issue.  The rules state you create your Motion Study and save after that.  You cannot save after that because it will create a new version that the Motion Study is not related to.  This is stated in the instructions.
As far as the Screencast, just copy and paste the URL, do not try and attach it.
Message 8 of 11
No avail. But as I said the sc doesn't show anything: https://autode.sk/3zPTylf
Message 9 of 11
This one is without saving inbetween.
Message 10 of 11
jhackney1972
The assembly file does not contain a Motion Study, could that be the reason you can not use it in a Render?   It also does not even look like your screen capture.
Message 11 of 11
rushabhthakkar_910
Good Video to Help you.. https://youtu.be/L_Idi7sOuZk ; https://www.youtube.com/watch?v=GJD2_u0s2z0
Thanks and Regards,
Rushabh Thakkar.
