more export file format
jean-michel_legoff
jean-michel_legoff
Could it be possible to add to more file formats in the downloadable list in Fusion Team?
I mean at least 3MF for 3d printing and GLB for sharing easier viewing file format.
Many Thanks
miechh
With the latest version of Fusion, the Manufacturing module has FFF printing which I think is totally AWESOME! The strange part however is, if you want to define another Platform Mesh inside the machine configuration, you can upload it to the machine in question, but the file-format has to be 3MF....🤔 I have my 3D printer reverse-engineered in Inventor. There could be several ways to convert the Inventor-assembly-file of the buildplatform to 3MF, but that's not possible with Inventor. Neither is it by uploading the Inventor assembly to Fusion 360 and export/convert it to 3MF, because there's no way to export to 3MF from within Fusion.... I understand that Autodesk is a member of the 3MF consortium, but they don't support this fileformat in the most important Autodesk software? Has this problem been addressed in the Ideastation of Fusion?3MF filetype needed....3MF filetype needed....
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
jean-michel_legoff
I agree,
But generate a 3MF is not so difficult.
Export your file in STL or OBJ open it in 3DBuilder (a free utility from Microsoft) and save it as 3MF
It’s fast and simple.
