Modify/Delete Holes in a pattern.
dcrouch9
dcrouch9
Can I create a pattern of holes and then remove or edit selected holes?
brucehuang
Hi, you can pattern a set of holes, and you can use suppress to remove some of them when creating or editing the hole pattern feature (from timeline for a parametric model, or from the browser entry for a direct model). For hole editing, you just can edit the source hole in parametric environment. If you are working in direct environment, you cannot edit the hole which has been absorbed by the pattern.
Let us know if you have further questions.
Bruce Huang (Fusion Development)
dcrouch9
That's what I was wanting to do.
Dana
