modeling plane
modeling plane
830403205
modeling plane
830403205
it would be very handy if one could choose the modeling plane from the home block in the top right hand side
thanking u kindly
SaeedHamza
What do you mean by "modeling plane"?
Saeed Hamza
Drewpan
If you are referring to the plane that you sketch upon and subsequently extrude your model then technically you
already can select those planes with the three planes at the Origin. I would suggest that the reason that you cannot
select the sketch plane from the view cube is that you can select many more planes than simply the six primary
views.
Sketches and extrusions can be placed on any plane and planes can be generated through the top menu selections
where such things as offset planes and planes at an angle can be created from geometry you have created. It is
possible to create completely custom planes with three points in space that the view cube simply would not be
able to handle.
The current system is also more or less a common standard used across many software packages and fusion wants
to be different and unique, but not to the expense of new users being confused because the software is too unique.
Cheers
Andrew
CREATE SKETCH THEN U CHOOSE PLANE. TO SKETCH ON
THANKS
MAYFREIND
NO MY FRIEND U HAVE MISUNDERSTOOD WHAT I HAVE SAID,I HAVE BEEN USING FUSION FOR A NUMBER OF YEARS AND KNOW IT WELL. I WAS SUGGESTIONING AN ADDITIONAL WAY ONE COULD CHOOSE THE PLANE ON WHICH THE CREATE THE DRAWING, WHICH WOULD BE VERY HANDY .
AND PLEASE DO NOT BE NASTY TO ANY BEGINNERS. YOU WHERE ONE AS WELL WHEN U STARTED
TrippyLighting
Here are some observations:
1. Most of the post you've made in the posts were written sloppily, with no respect paid to grammar and punctuation. Windows and macOS provide native tools to alleviate some of it and even the free version of Grammarly does a fabulous job of cleaning up that stuff.
It also appeared that you made no effort to explain the problems or issues well.
As such, you might want ask yourself why the responses you get do not address you problems!
2. Do not type in al large letters. Since the dawn of the Internet this is regarded as yelling and rude behavior. There is no need or place for this on the forum.
In case English isn't your native language, it isn't mine either. It took some effort to learn it 😉
