Modeling mathematical shapes
Does the 3d Plot add in work in Fusion 360 ?
Is there any way of modelling by using a mathematical function ?
Thank you.
Hussain
henrycassonJRZ79
Obviously a disgraceful Kluge.. I would graph the function in Excel, Draw the graph, put the picture in the background in fusion, and run a spline along the curve. I did it for a cycloid for a horological project. If you work at a big size it can be accurate enough.
Hi Henry,
Thanks ! , Thats a pretty good idea !. Had not though of that before !.
Any idea about 3d mathematical models as well ?
Hussain.
mavigogun
If you can describe points of the shape mathematically- say, for faceted shapes like Platonic Solids -points can be moved into position with precision, connected by sketch lines, Patched, etc.
TheCADWhisperer
@Anonymous
In Autodesk Inventor Professional you can enter equations for 2D or 3D Equation Curves.
Students can download Autodesk Inventor Professional for free from http://www.autodesk.com/edcommunity
2D Equation Curves2D Equation Curves3D Equation Curves3D Equation Curves
Downloaded !! thanks a lot.
