Modeling Foam
Modeling Foam
Message 1 of 14
Modeling Foam
 I am trying to model foam or a spongy material with a random piping pattern similar to the photo shown above.  I've tried Voronoi sketches but that means one/two of the axes are the same throughout the structures.  Any ideas?
Replies (13)
Message 2 of 14
TrippyLighting
In Fusion 360 I would model this manually with a T-Spline.
For a procedural approach I would see if Blender can do it but I am fairly convinced this can be done with Houdini.
Can you elaborate a but more on the use case for your particular project ?
Edit: Actually in both Blender and Houdini the technique is called Voronoi Fracture and there are youtube videos available that explain how to do this.
Message 3 of 14
I'm trying to make a 3D cube with the foam pattern from the picture above so that I can later intersect/do some Boolean operations with the pattern and another object. In other words, I need a foam structure instead of an appearance or a surface sketch like the Voronoi fracture add on for a physical 3D model.
The piece I want to eventually print is pretty large so making T-Splines manually might not be feasible just because it would take so long. Ideally, the structure would be 100% random as well.
Message 4 of 14
SaeedHamza
My approach would be to create a voronoi sketch and apply pipes to it in the sculpt environment, and pipes should be created in one pipe command ( same dialog box ) so that they are attached
Might help
Regards
Saeed
Saeed Hamza
Message 5 of 14
TrippyLighting
The problem with that is that the pattern would not fill a 3 dimensional volume.
Message 6 of 14
SaeedHamza
I feel that this is something similar to what I do when I create a building as a mass in Fusion and insert it into Revit as a conceptual mass
you see creating an opening in a mass ( especially a fluid one ) in Revit is a problem, so I use the split face command to create openings in Fusion, I hope it makes sense if your not familiar with Revit
Anyway what I'm saying is to use the split face command to project the sketch on the body in 3 dimentions, something like this :
Then use the pipe command on it to create the pattern
Might be a similar case to his ...
Saeed Hamza
Message 7 of 14
TrippyLighting
This approach to creating recursive and generative patterns is really what the Grashopper plugin in Rhino was developed for and I believe this would be fairy forward to so in Rhino.
Fusion 360 has absolutely nothing in the pipeline for this which is really very unfortunate.
Message 8 of 14
SaeedHamza
Ya I agree, Fusion is not functional when it comes to complicated patterns
I believe it should be in future though
Saeed Hamza
Message 9 of 14
cekuhnen
@Anonymous @SaeedHamza @TrippyLighting
This is pretty easy while labor intensive and would need a volume based cell structure.
I assume that Fusion T-Splines is not the best idea at the moment for this.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 10 of 14
@cekuhnen
I am having the same problem as the original poster and would really appreciate if you went into more detail about what you mean by needing a "volume based cell structure."
Do you mean that I would need some kind of scan of a physical model then import it that scan into Autodesk Fusion?
If not, can you go through the workflow you would do to CAD these structures?
Thanks so much!
Message 11 of 14
cekuhnen
@Anonymous
What I mean is you need to build that by hand with a polygon sub-d system and it will take some time
or use a volume fracture system to create the base outline which you can pipe along!
Claas Kuhnen
Message 12 of 14
Hello, Can you explain in details as to how to use the T-spline to make it porous?
Thanks!
Message 13 of 14
TheCADWhisperer
I doubt it.
Message 14 of 14
TrippyLighting
@TheCADWhisperer wrote:
I doubt it.
Correct! I cannot explain that.
