Modeling Error: Can't create patch toolbody, please check the inputs. help!
Hi guys
new to fusion 360 so i was wondering if anyone can offer some advise.
Im trying to build a model of a guitar neck and im having a problem with the patch tool and im getting the following error.
The area is a small triangle on either side of the heel transition on my guitar neck model
any ideas as to what my be causing the problem ?
https://a360.co/2S2MwV1
jeff_strater
Thanks for sharing the file, @jak3tayl0r .  This is a bug in Fusion - the preview and final commit use slightly different logic to determine if the path is "closed".  There is a workaround, though (a bit on the ugly side, but it does work):
  • create a Base Feature
  • do the Boundary Patch in the Base Feature
  • exit the Base Feature
  • Stitch the surfaces together
this is also the same problem reported in this thread: patch-problems
Jeff Strater
Engineering Director
Wayne_Carlson
More than 3 years later I'm still getting this symptom.  The preview is fine but compute error on the patch.  Thanks for the workaround, it worked for my case.
andrewQFQPJ
Community Visitor
Community Visitor
After hours struggling with this issue, you saved me probably throwing myself off a bridge somewhere. Thank you!
