Modeled Threads are closed
Message 1 of 12
Most of the modeled threads are closed in the end of the helix. You cant really use them if you print them out.
Replies (11)
Message 2 of 12
lichtzeichenanlage
Is it possible to attach an export of the design or a link to the project?
Message 3 of 12
without the extrusion on the end of the timeline the thread is not open
or did i something wrong? 😕 ?
Message 4 of 12
lichtzeichenanlage
But isn't the fillet / chamfer the problem?
Message 5 of 12
No
i have never seen a screw or a thread without a proper chamfer.
you cant machine straight cut threads, and if it would not be practical.
and it is really hard to ad a chamfer after you made the thread
Message 6 of 12
lichtzeichenanlage
Sry for my bad english. I didn't mean in the real world but in the way to modle it in F360. I just had a video in mind where they have shown that the order of the features are important. I can not find the video anymore, but this should show what I mean:
https://forums.autodesk.com/t5/fusion-360-design-validate/chamfer-threaded-rod/td-p/5946660
Message 7 of 12
TrippyLighting
Erstens ist dein Englisch ja nicht schlecht und zweitens kannst du dich mit @Anonymous auch in Deutsch unterhalten 😉
@Anonymous this is a limitation of the chamfer tool in conjunction with modeled threads. You’ll simply have to chamfer after applying the thread. It not hard. It’s just a PITA.
Message 8 of 12
lichtzeichenanlage
@TrippyLighting: That's very kind of you and thank you for pointing out that speaking German is always an option ;-). But I do not want to be rough to other members of the forum who do not speak German and I do not want to downgrade the value of an discussion for others.
Your description of the implementation was what I wanted to say.
Message 9 of 12
Alles gut 😄
Danke für die Hilfe, ich war gerade nur überrascht das mein Druck nicht nutzbar war ^^
Message 10 of 12
JDMather
Turn on your sound.
Message 11 of 12
TrippyLighting
I removed the solution marker from my post and applied it to yours. Thanks!
Message 12 of 12
sweet thanks 😄
