Model STL missing parts
Hello all,
I Find many solutions for similar problems in forum but do not found one solution for my issue.
I created a model in fusion with this layout
In fusion the model view its great and all walls is visible.
But when i try do slicer in cura has a missing walls in the model.
Can i solve this problem or need to draw again? I am Trying to change size of shells, remodelate parts of the project but always is missing.
LeonardoBN
Olá, @Anonymous.
Could you share the F3D file?
What is the thickness of that missing parts? Are you slicing with a 0.4 mm nozzle?
Leonardo Brunelli do Nascimento
Chemical Engineer
Thank you @LeonardoBN  for fast response.
I changed the size of nozzle to 0.2 to test but not solved.
The file is here, thank you again.
dankG2KYJ
@Anonymous Did you slice this in vase mode?
Sorry for this!
Yesterday a slice another file and changed this configuration! Thank you @dankG2KYJ
