Model Stack-up
Model Stack-up
Model Stack-up
As you all know sheet metal in fusion 360 is out and i love it so i want to design a casing for my workstation so i imported the mother board and other model but the problem i'm having is i cannot move any model. I tried to create an assembly in fusion then move the component and works the way i want but for imported model it does not allow me to do it, i checked the model if it is grounded but it is not.
Another is where i can find the joints history?
Thanks for any helps
<iframe width="640" height="590" src="https://screencast.autodesk.com/Embed/Timeline/b183f41c-0e11-4d22-9bb7-3275926a827c" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
TrippyLighting
Geometry imported from other formats are imported in direct modeling mode. Per default (this can be changed) you cannot move components in the viewport by dragging them around.
You can use the move command to move them to the desired location, to you can use a joint from the Assemble menu.
why fusion does not allow to move it by dragging in the view port while in inventor it allows me to drag. I think this is something the fusion should do to become much more user friendly coming from solidworks is a bit frustration to a simple thing that should be done. If it is not a bug i think i like raised in the idea station.
TrippyLighting
This default setting can be changed, which I told you already in my reply.
Fusion 360 is not Inventor and hand utilizes different concepts in several areas. I personally don't want Fusion 360 to be like Solid Work, or Inventor.
I've worked with Solid Works for 15 years professionally (and CAD in general for 27 years)  and don't find Fusion 360 less user friendly.Quite the opposite actually!
