Model cam slot in cylinder for machining in Turn-Mill with rotary capability.
6 REPLIES 6
jrprogramming02
403 Views, 6 Replies
Hi. I need to know how to go about modeling the cam slot in this cylinder, but in such a way that we can machine it in our Turn-Mill with Fusion's CAM functions.
End result needed: a "theoretical cylinder" such as a gage pin to passes through the slot. Our current model is not compatible with our machine capabilities.
We are putting this on a Nakamura-Tome WY100. I'm fine with extensions as needed. We don't have 5th+ axis capability. Rotary, X,Y,Z only.
Labels (1)
6 REPLIES 6
@jrprogramming02
Rather than a STEP file-
Sure. Here you go. If you need design history, I'll need to remake it. The full design contains proprietary information.
A Fusion file without history is essentially the same as a STEP file?
https://www.youtube.com/watch?v=Wekmai5MqFM
If this were my design - there would not be any blue lines or white dots and I doubt those splines would be in my design either.
I tried to pick up your dimensions and place the desired slot on the opposite face.  Please check them behind me.  Model is attached.
John Hackney, Retired
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
I didn't get the notification of your reply and missed it. Here are the specifications for the 2D sketch. We need to wrap this around the axis of the cylinder in such a way that we can machine it with a 3+ axis turn-mill. The file you submitted didn't replicate the results we're looking for, unfortunately. We'll keep trying!
@jhackney1972
