Modal Toolbox, operation menu, and command dialog ??
--------------------Issue #1 ------------------------------
I am here:
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-FDF4912D-0A79-4E35-ACD1-7B9A73F6D2B7
under this topic:
To access commands using the toolbox
The Toolbox is a customizable method to access frequently used commands.
Use the toolbox to access frequently used commands. Each workspace has its own toolbox.
But I could not find the model toolbox on F360.
How do I display it?
--------------------Issue #2 :  Assembly ------------------------------
And I am also here:
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-E37B0456-A867-429F-BF69-6A4626DD31E7
under:  "How do I create bodies?"
and it has this instruction:
"Most commands in the "Create" menus (Box, Cylinder, Sphere, Extrude, Revolve, Sweep, etc.)
can create new bodies. Choose "New Body" from the Operation menu in the command dialog. "
I have been doing several tutorials already using the toolbar, but I am not sure what this is:
"Operation menu in the command dialog"
Where is the command dialog and where is the operation menu?
I went back to "setup and orientation" section and also here Lesson 3: Navigation and
Lesson 2: User Interface , to see if I miss this, but I could not find it
on F360.
Thank you.
OK, I think I found answer for this:
-----Issue #2 : -------
The command dialog is the dialog that pops up
after i drew the box.. And operation menu is
an item in command dialog with a drop down list.
I only wish the author would have explained it like this.....
knobbsa
Hello @Anonymous
Thank you for the feedback.  We'll add the details you're outlining in #2 to the topic so that it's more clear.  Sometimes internally used terms get put into our content unintentionally and it's a great point that we could clarify these terms more in this instance.
For #1, make sure that you don't have anything active.  Either you're looking at a model or a blank canvas without being in the middle of using a tool or feature.  Hit "S" and the model toolbox should open.
Please let me know if this still doesn't work.
@knobbsa:
Thank you .
Here are the steps in the turorial:
To access commands in the toolbox
  1. With no command active, type "S".
  2. Click the desired command in the toolbox.
should be rewritten as:
To display the Model toolbox and then access commands in the toolbox
  1. With no command active, type "S" to display the Model Toolbox.
this will make a huge difference for new users.
