Mix metric and imperial dimensions in one sketch?
People might consider the bad form but I want mix both systems of measurements of the same drawing. I have a part that is made of .375 inch aluminum plate and has holes spaced on 47mm centers. I'd like call out each dimension in it's natural units.
I was happy to find that Fusion 360 can do the inch <-> mm conversion for me. If the design uses inches I can type "47 mm" and Fusion shows 1.85 on the sketch. But what if I want it to show some dimensions in mm and some in inches.
The best I can figure out is to just use one system and then make notes that read something like "1.85 should read 47.0 mm"
One could argue that this problem is only cosmetic because the part is modeled correctly. It is, but one important goal of technical drawing is to communicate.
