Missing Constraints Menu
leeackerson
Message 1 of 10
leeackerson
The constraints menu used to reside on the right side of the screen where I could minimize it or maximize it, but now is totally gone. How can I get it back?
Replies (9)
Message 2 of 10
masa.minohara
Hi @leeackerson,
Thank you for posting! Could you try "Reset to Default Layout" in the File menu to see if that fixes the issue?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 10
I have the same problem, no Constraints menu on the ride side of the screen. But it does not help to reset to default Layout. Fusion 360 was installed yesterday the first time.
Message 4 of 10
HughesTooling
With the update to the new UI the constraints have been move to the top menu. As normal buttons you can now add hotkeys and also add to the "S" menu.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 10
Already noticed that the Constraints bar is at the top menu, but it´s very inconvenient to open the drop down menu every time. I watches some videos on youtube last days and all of them have the bar at the ride side where it´s much easier to navigate. So is it possible to get it to the ride side of the screen?
Message 6 of 10
HughesTooling
No.
Mark Hughes
Message 7 of 10
Thank you very much.
Message 8 of 10
HughesTooling
Have you figured out the other changes to the UI? Here's a link to the new UI in the help.
Mark
Mark Hughes
Message 9 of 10
I did now after you mentioned it. And there is a way to get everything back like I wanted to. Open preferences -> common and then enable the last checkbox to activate the old toolbox.
Message 10 of 10
HughesTooling
That option will go away after the next update or two so sooner or later, probably sooner you will have to use the new UI. You can add the constraints to the S key search toolbox so they pop up at the mouse.
This is my search toolbox in sketch mode.
Mark
Mark Hughes
