Minor annoying behavior when moving sketch geometry via prompts
Analias
Analias
I've noticed a minor annoying behavior when selecting and moving geometry in a sketch.
I enter the edit mode for the sketch and select the geometry I want to move.  I right click to bring up the menu and select Move.  The Move dialog window comes up.  I select a distance prompt to change and start entering a numeric offset.
After the first digit is entered, there is a noticible pause as the manipulators in the sketch reposition relative to the value I entered, and my cursor is unfocused from prompt input.  The pause I can deal with 🙂  Taking the user's input focus out of the numeric prompt is high sin in UI design - it violates the principle of least surprise.  I have to reselect prompt and finish entering my number.  Oddly the delay and unforcusing doesn't occure with each number entered, just the first.
-Freeman
haughec
Hi Freeman,
Thanks for reporting this issue.  This is definately a bug.  Focus should not be removed from the value input control unless you select another value input control or another Manipulator (or press the Tab key, which does the same).  We'll work to get this issue resolved promtly.
Charles
Charles Haughey
Fusion 360 User Experience Architect
haughec
I've logged FUS-15812 to track this issue internally.
Charles Haughey
