Milling af handle
Milling af handle
E_SADRIA
Message 1 of 8
Milling af handle
E_SADRIA
Dear Autdodesk community,
I want to illustrate a handle milled.
I am having challenges in creating a 45 degree chamfer of the handle that would give the user an easier grab option.
Can someone help me understand if i am using the correct function?
Attaching my drawing.
Replies (7)
Message 2 of 8
deutirium
This looks like a design problem to me rather than a manufacturing one, if I understand correctly. Perhaps you will get better help in the Design forum.
Message 3 of 8
davebYYPCU
Like this?
Minus 45 degree draft.
Might help...
Message 4 of 8
E_SADRIA
yes!
Message 5 of 8
E_SADRIA
But only to the left side...
Message 6 of 8
davebYYPCU
Sketch for an Extrude or Sweep > Cut.
Might help….
Message 7 of 8
E_SADRIA
So you would
1. Create a mass
2. Create a sketch line (the oblong handle)
3. Sweep -> Cut the mass
Message 8 of 8
johnsonshiue
Hi! There are multiple ways to create the shape. You may also leverage Solid Sweep, mimicking the machining process. Basically, create rod with a cone at the bottom. Then create a Solid Sweep cut with the tool along a straight line.
Many thanks!
Software Test Engineer
