Mesh to Solid -> Then combine/cut another solid
kzydave
kzydave
I have imported a mesh into a new design, reduced the facet count (8300) and then convert mesh to BRep. This is all fine, but I wish to then use this new solid from mesh to combine/cut from another solid. You can see from the screencast I have a large block I wish to shape the bottom from the mesh solid so its. half flat and half mesh face.  I can't actually combine/cut the bodies so that I can then use the top half. You can see from the second half of the screencast I have already done it once a few weeks ago, just can't seem to work out how it did it the first. time.
Adding some gauges to my new Swift Sports. 🙂
have a Prusa MK3S so will print from black PETG.
Attached the Design I'm trying to play with.
What am I doing wrong here? is there another way to approach what I need as the base?
davebYYPCU
Close, it’s Extrude > Cut, make the profile big enough to trim the complete lower section away.
Might help....
kzydave
I may have also selected the solid rectangle object, then tried to split the body by then selecting (left click->drag) over the bottom part of the new Solid/mesh facets. Fusion goes into a memory overrun.
kzydave
So I found if i turn history off and then select Combine/cut....
Select the box as the body from left tool menu
Select the BRep body from the left tool menu I can then select OK.
The error I then get is: no intersection between target and split tool
davebYYPCU
Works for me,
Might help....
laughingcreek
@kzydave -The combine tool only works on solids, not surfaces.  the tool you used before was Split Body.
