Mesh Sections questions
JustaBill
Message 1 of 10
JustaBill
Couple of questions about mesh sections
- Is there a way to delete part of a created mesh section? ( example in snip keep blue, remove red )
- The fit curve to mesh ellipse previews one thing than when used it is actually does a circle larger than the circle fit curve type, ( cant screen shot the preview due to needing mouse to snip )  I can come close to the preview with a closed spline fit curve type if I increase the tolerance to .063 ( as shown in 2nd snip ) Is that due to the max curve deviation of the different types? ellipse - .03136, circle - .117 and closed .05699 Is there a way to dictate max curve deviation of the ellipse and circle fit curve types? Thanks! Capture.PNGCapture2.PNG
Replies (9)
Message 2 of 10
HughesTooling
Can you share the design? Never used mesh sections on a part quite like this and I'd like to experiment.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
JustaBill
Think I'm going about this the right way....All I did was set a big block with holes, ran through shape optimization and promoted the mesh itself to the model work space. Have fun!
https://a360.co/2R8rGTe
Message 4 of 10
HughesTooling
Would you mind exporting the file as an f3d, there's an export option on the file menu. The share links are slow and unreliable.
Thanks Mark
Mark Hughes
Message 5 of 10
JustaBill
Sharing files etc is new trick for me, let me know if that does it.
Message 6 of 10
HughesTooling
The attached file worked fine.
Is this what you mean? The white ellipse is the preview and the pink circle is the result after clicking OK.
I've attached my file with a mesh section, @jeff_strater is this working correctly?
Thanks Mark
Mark Hughes
Message 7 of 10
JustaBill
Yup, that looks to be about it. If the same section geometry is selected for the circle instead of ellipse in comes in about 1/2 between the 2. So increasing in size it goes closed spine < circle < ellipse.
Message 8 of 10
HughesTooling
A workaround might be to use the ellipse\circle from the mesh section and just draw an ellipse using the standard ellipse tool from the sketch menu.
This might actually give you more control as you can constrain the ellipse.
Mark
Mark Hughes
Message 9 of 10
JustaBill
I like the work around. And being able to dimensions will be handy. It's actually step or 2 farther along than what I'm needing right now but absolutely on the to-do list.   This post is tied into another post I had yesterday about sculpting. https://forums.autodesk.com/t5/fusion-360-design-validate/tubing-a-mesh-shell-thicken-offset/m-p/830...
End goal being able to take the mesh, loft it out and thicken/shell so it is a tube-ish with X wall thickness.
Message 10 of 10
jeff_strater
yes, that looks like a bug.  I don't see the exact same behavior - I don't see the white preview that looks correct, but the result is still wrong.  Your workaround is a good one.
[edit]  Never mind, I was on the wrong section, I see the same behavior as you.
[edit2] filed as FUS-43690
Jeff Strater
Engineering Director
