Maybe (hopefully) this is straightforward: Imported a mesh, created offset planes with mesh sections (about 10 planes/sketches). Double clicked on those mesh section sketches and created some sketch lines based on the mesh sections. I did this using freehand modeling, did not use the "fit curves to mesh section", though the end problem is the same either way.
The problem is that no profile I create on those sketches is closed. Even if I just use the circle tool off somewhere to the side of what I am working on, that circle is not a closed profile. That is a problem!
Other sketches work fine, and if I create another sketch right on top of the mesh section sketch and project the mesh section sketch, the profile becomes closed. Is that the intended functionality? If that is the intended functionality, then I would need 10 mesh section sketches and then another 10 projected sketches in order to continue with modeling?
Thanks!
Nick Kloski
