@HughesTooling
Create mesh section doesn't work with infinitly thin meshes without triangulation. (Although I think the biggest issue is non-planar faces.)
They need to have some sort of thickness or planar faces, but still triangulating the mesh to create a mesh section is the hard way to be doing this and leaves a lot of room for errors and less accurate models.
It's fine if @conorBreen wants to work that way but then I would have to ask why use a CAD app at all if you don't care about accuracy?
Also if you have Zbrush you eliminate the need for the mesh space in Fusion altogether. I guess that is the real point I am trying to make here.
Phil Procario Jr.
Owner, Laser & CNC Creations
