Mesh Error on Simple design
jamesf2SRYX
Message 1 of 8
jamesf2SRYX
Hi All
can anyone assist as to why this model wont mesh properly.  Ive tried various mesh sizes and options.
The model is really simple.  I seem to be having this more often.  I often re-do the model exactly the same and that time it will work.  Not sure what im doing wrong.
Its for a vessel under external pressure.  Rigid body modes removed.
https://a360.co/3SLVFQ7
Replies (7)
Message 2 of 8
jhackney1972
Here you go.  Your end caps had a seam in the apex so I used surfaces to fix it.  You had a overlap between the main body and the tower base.  Model is attached.
Edit: please note the town section is not open to the tank so that may affect your results.
John Hackney, Retired
Message 3 of 8
jhackney1972
Questions about my solution?  If not, then please select the Accept Solution icon to clear your question from the board and allow others to find it if they have similar questions.  If so, please ask.
Message 4 of 8
jamesf2SRYX
Hi John,
Thanks so much for that.  Very much appreciated.
Would you mind explaining a bit more on how you found the problems and what you did to fix it?
Kind Regards
James
Message 5 of 8
jhackney1972
The video will explain, overall, what I did to correct your model so it would mesh in the Simulation Environment.  I will mention it again that your the tower is not open to the tank so this will probably not give the results you desire.
Message 6 of 8
jhackney1972
I have explained how I determined the errors and showed the solution, do you need further help?  If not please mark the post that solved your Forum post Accept Solution.
Message 7 of 8
jamesf2SRYX
Hi John Thanks for that.  I will review the video a bit later, im at work at the moment.
Yes, i realised id not opened up the tank when the results of the simulation loaded.  was a bit too good to be true...
Thanks again.
Message 8 of 8
jamesf2SRYX
John, I just watched the video.  Thanks for taking the time to explain that for me.  The fact that it didnt knit in the centre of the revolve is interesting.   Also the way around it was nice with the surface revolve and thicken.
This will help me in future.
Kind Regards
James
