Mesh conversion and step export
berger_ferdina-mb21
Message 1 of 14
berger_ferdina-mb21
I have the problem that after converting a mesh into an organ model I have a T-spline mesh body which I cannot export as STEP.
If I can then convert the model. If I want to convert the image, I have to select each edge individually, which is not possible with more complex models. Is there another solution for this?
Many thanks for your help
Ferdinand
Replies (13)
Message 2 of 14
g-andresen
works for me.
Please show your process in a screencast.
günther
Message 3 of 14
berger_ferdina-mb21
Is there another way to keep the edges? Then the single selection. Can I select the edges with the area selection or something similar? In larger models I can't select every single edge. This menu opens when I right click on the mesh body.
Message 4 of 14
TrippyLighting
Can you explain why you want to keep all the edges?
Message 5 of 14
berger_ferdina-mb21
Yes, I have to select the edges so that I can convert the mesh. Otherwise Fusion gives me an error. Or am I on the wrong track?
Thank you
Message 6 of 14
TrippyLighting
@berger_ferdina-mb21 wrote:
... Or am I on the wrong track?
Possibly. Can you share the model so I can see what the error is and perhaps suggest a fix?
You can export the model as a .f3d file and attach it to a forum post.
Message 7 of 14
berger_ferdina-mb21
Enclosed is the file.
I have converted an STL into the model which is attached. I would now like to export this as a STEP file. So far I have always received the error message described.
thanks
@TrippyLighting
Message 8 of 14
TrippyLighting
Scratch what I posted here before!
I see what you mean. Usually this is just a warning message and all "normal" solid bodies and surfaces are exported.
You can either delete the T-Spline body, or turn on the timeline.
Then the export works!
@Phil.E I would classify this as a bug.
Message 9 of 14
berger_ferdina-mb21
okay, thanks. Now I can do it
Message 10 of 14
Phil.E
It's not a bug. The file has a t-spline body because it's not parametric.
Turn on the timeline and it will export as a step without complaint.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 14
berger_ferdina-mb21
Yes, I have done that. Now it works.
Thank you
Message 12 of 14
TrippyLighting
Thanks for the feedback!
Message 13 of 14
laughingcreek
@Phil.E wrote:
It's not a bug. The file has a t-spline body because it's not parametric....
I don't understand why this would be expect or desirable behavior.
if I have a DM model with a bunch of bodies in it, and hide all but one, then just the one body will be exported to a .stp.  if one of those (hidden bodies) happens to be a t-spline, then I can't.  that makes no sense.
Message 14 of 14
Phil.E
I don't disagree with you. All I'm saying is that it's not a bug if the software is performing as-design.
The warning looks pretty clear to me. But perhaps this could use more words to help users. I'm open to suggestions.
And you can export the design, if it has a timeline. That's the main thing missing from this dialog box, IMO.
Also, just to be clear: I'm not a manager, developer, user experience designer, or decision maker. I help forum users understand the product, and report issues.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
