Mesh Alignment
Mesh Alignment
dawie_lindeque
Observer Observer
Mesh Alignment
dawie_lindeque
Observer
Observer
Hi. I was thinking that the mesh align has a problem in that the triangles are not well aligned with the surface you want to capture. I think what you would really want to do is to capture a number of 3-point planes, then take the average of those planes as the plane you want to align to another plane. In practice, what I do, is to  construct a 3 point plane, then another one (using points very different from the first one, but on the same mesh surface), then I draw a sketch on the first plan and drop down 3 points, then create a sketch on the second plane, and project the points from the first sketch here. then I construct a 2 point axes through each of those sets of points, and find the mid point, then I use those 3 mid points to construct the final 3 point plane. If this was automated, I image you can use more than 2 planes to get a more accurate final plane. What do you think about automating this process?
TheCADWhisperer
@dawie_lindeque
Can you attach your example here?
bhavani_sankuratri
Hi @dawie_lindeque ,
Thanks for sharing the details of your issue.
We wanted to follow up and check whether you had a chance to review the response from TheCADWhisperer.
Incase if you have already found a solution, could you please share what worked for you? It may help others facing a similar problem.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Bhavani Sankuratri
