Merging bodies - boolean error?
technewbie
Message 1 of 11
technewbie
Trying to merge these 6 bodies into one body gives a boolean error? Have tried to use the AI support function but it didn't offer much in the way of a clear explanation. Can anyone tell me what I am doing wrong please?
Replies (10)
Message 2 of 11
TrippyLighting
Can you share your design in native Fusion format (.f3d) ?
Message 3 of 11
technewbie
Sorry, here is the .f3d version
Message 4 of 11
TheCADWhisperer
@technewbie
I recommend that you turn on Capture Design History and start over.
That is what I am going to do.
I assume that you will then want to Shell...
Message 5 of 11
TheCADWhisperer
@technewbie
There was a trick in my technique that I did not yet reveal.
Did you figure it out?
Message 6 of 11
user015M86Y
@TheCADWhisperer
Shell should be done after loft the single part
Message 7 of 11
TrippyLighting
I fail to see how that would return a useful result.
Message 8 of 11
TheCADWhisperer
@user015M86Y wrote:
@TheCADWhisperer
Then do it - and be sure to attach your result here for others to see how it should be done.
Message 9 of 11
user015M86Y
@TheCADWhisperer,
see attached the result
Message 10 of 11
TheCADWhisperer
@user015M86Y
What is the function of the part (take a guess if not known for certain)?
Message 11 of 11
etfrench
Projecting the bottom to a sketch on its face shows that it is not a circle.  Fix this and a loft between that and the tops of the arms works:
p.s. Start over and turn history on.
p.s.p.s Ignore this, I used the bottom of the loft instead of the flat disk.  Just do the start over😁
ETFrench
