mechanism using pulleys
chuck767
Message 1 of 8
chuck767
I have two pulleys with a belt between them to drive a mechanism.
I cannot figure out how to configure this mechanism using the two pulleys and belt to drive the mechanism
any help would be greatly appreciated
thanks,
Chuck
Replies (7)
Message 2 of 8
Bunga777
In the current state of Fusion360, the only way to drive pulleys is to use Motion Link to drive them in the same way as gears and sprockets.
Although many tricks have been invented, there is no function that can perfectly reproduce the complex contact drive as a fundamental function, and I feel that the best method for now is to use Motion Link to simulate it.
I too would like to see more of this type of functionality. I hope it will be implemented.
Message 3 of 8
chuck767
Thank you for the quick reply. I will not spend anymore time trying to make it work.
Chuck
Message 4 of 8
MichaelT_123
Hi Mr Chuck767,
Pulley's type design requires both concurrent changes in the geometry of the mechanism's elements and their synchronized movements.
Unfortunately … in F360 Ultimate, sections of the kernel responsible for these functionalities… seem to be separate, making dynamic harmonization of the design's elements difficult (or even impossible).
However, contrary to some opinions, it is possible to perform a partial simulation of the design, limited to geometrical changes only (without pulleys rotations). It should be sufficient in many cases to properly place the pulley mechanism in a broader design context.
The not-so-good news is that, in general, even such partial simulation, CADing of pulleys will require some calculations and formulas derivations to establish respective userParameters set driving its foundation sketch, … and this might be a daunting task!
I am attaching a very basic/classic pulley design example. I hope that it is self-explanatory. Use the _Rope_Release parameter to pull/release … a rope. Unfortunately, you will not be able to 'rotate' pulley disks concurrently.
Pulley_mono.png     4K_mono ( 0.7MB)    https://a360.co/3ikpRV3
Pulley_arcd.jpg        4K_stereo ( 0.2MB)   https://a360.co/3ikmtcO
Pulley_mono.mp4    4K_mono  (6MB)      https://a360.co/3VzD1vO
Pulley_arcd.mp4      4K_stereo  (13MB)    https://a360.co/3gGWP1z
To be viewed on 4K media devices (monitors, UHD TVs, projectors...) of reasonable performance. For the best experience, use stand-alone media applications (WMP, VLC) and the native resolution 3840x2160 - full screen. The '_arcd' files require an anaglyph red/cyan glasses, while '_al' is for active shutter glasses 3D hardware (~30 deg viewing angle is recommended). Download the files over a network, where the cost of doing so is not a concern. The files are to be used for private, non-commercial purposes only.
Regards
MichaelT
MichaelT
Message 5 of 8
chuck767
Thanks for your input, very impressive. I could not get the video of work because of my monitor.
Message 6 of 8
MichaelT_123
Hi Mr Chuck767,
I realized that I haven't attached the demo f3d file. I will do it in a few hours time.
Regards
MichaelT
MichaelT
Message 7 of 8
MichaelT_123
Hi Mr Chuck767,
Here is the updated pulley
I repost my previous one in its entirety… as I have found that I messed up with radia&diams 😞. Thus please consider the past attached files as … digital rubbish… and treat them accordingly.
Uffff … nobody spotted it !!! 😂
Hence, we go …
Pulley.f3d                  F3D            ( 0.2MB)   https://a360.co/3XH25Tr
Pulley_mono.png     4K_mono ( 1.2MB)    https://a360.co/3iqnyQk
Pulley_arcd.jpg        4K_stereo ( 0.2MB)   https://a360.co/3XINYwS
Pulley_mono.mp4    4K_mono  (7.2MB)    https://a360.co/3ATpAPw
Pulley_arcd.mp4      4K_stereo  (25MB)    https://a360.co/3XDZsSp
To be viewed on 4K media devices (monitors, UHD TVs, projectors...) of reasonable performance. For the best experience, use stand-alone media applications (WMP, VLC) and the native resolution 3840x2160 - full screen. The '_arcd' files require an anaglyph red/cyan glasses, while '_al' is for active shutter glasses 3D hardware (~30° viewing angle is recommended). Download the files over a network, where the cost of doing so is not a concern. The files are to be used for private, non-commercial purposes only.
Regards
MichaelT
MichaelT
Message 8 of 8
chuck767
very impressive !!!
I have determined my pulley system is way too complicated to even try to
simulate it.
thanks for your input
chuck
