Hi all,
Apologies if this is covered, I did try to search for it.
I have a parametric model of a set of drawers within a carcass.
My parameters are based around Height, Width and depth of the carcass.
I want to use the existing height of the drawer as a named parameter (The height was extruded from a sketch allowing a parametric distance from the base board face, and a parametric distance from the drawer above)
I can use [H_Carcass - base_thickness - top_thickness - (Drawer_clearance*3) to derive the height of the drawer, but being able to use a measurement as it is in the model would be much simpler and remove the likelihood of user error by me missing something in the equation.
See image below.
