Measurement, Am i doing the math wrong?
Jake.Scott737
Message 1 of 8
Jake.Scott737
I want to make a Cylinder, will say 150mm on the outside Dia, 5mm high. Then I want to cut a hole in this object 140mm in Dia, 5mm high. Why when i get done doing this does it not leave me with a 10mm Ring 5mm high? It comes up 5mm's
Am i loosing my mind. or did some how they how change math?
Replies (7)
Message 2 of 8
JDMather
150-140=10
10/2=5
Can you Export your *.f3d file and attach it here?
5+5=10
Message 3 of 8
Jake.Scott737
Not sure where the file is i saved it but can find the File
Message 4 of 8
Jake.Scott737
though the First example is what i am saying is happening. why is it only 5mm wide and not 10mm wide?
Message 5 of 8
Jake.Scott737
here it is
Message 6 of 8
Jake.Scott737
the math of 10/2 = 5 is wrong. that is a Radial Measurement.
Message 7 of 8
JDMather
Are you familiar with the definition of
Radius
Diameter
in geometry?
Message 8 of 8
jeevesme
Because the outside circle is 5mm away from the inside circle.  You are using the term "wide" when you should be using "offset".
_________________________________________________________________________________________________________________________________________Forever yours,
Love,
Brian
PS. If this answered your question, please mark as answered so others do not read through the posts trying to figure out if it was answered.
