Measure results overlapping
vilts
vilts
Measuring between holes creates 3 overlapping dimensions displayed on top of each other, all being unreadable. And sometimes even the selection numbers (1 and 2 in this case) are on top of the black dimensions, making it even more impossible to read the results visually.
On larger dimensions it is possible to zoom in on the dimensions and decode what's what, but not on smaller ones like this example. And on the larger ones after zooming in, you can't see where the arrows point to.
Would be nice to get the separated somehow.
sanket223.patil
Hey , It is measuring the minimum, exact , maximum distance all at once . The distance is 0.147mm . In result window , the distance is original . But I dont know , how to change it .
Sanket Patil
Mechanical Engineering
Expert Elite
3DTS
This seems most prominent when measuring holes of the same size. This problem has clearly been ignored, pity. I know Fusion is permanently in a state of bugs between "updates" but this would have been a nice fix. Any suggestions would be great!
