Not sure this is the right forum ... but will give this a shot. Have done a search and not found an answer.
Is there a way to quickly get the DIAMETER of a SPHERE with the MEASURE tool? (or some other tool?)
MEASURE seems to only return AREA??? (And sometimes loop length).
In the attached image (also below) I would like to know the diameter of the blue sphere.
Clicking on it with measure returns AREA only (yes I could do the math, but why?).
Am I missing something? Thanks in advance for your help.
steve
Solved by hex705. Go to Solution.
Solved by laughingcreek. Go to Solution.
What a strange problem. The only way I saw to do it is to create a sketch, and "project" the sphere body onto it. This will create a circle in the sketch that you can measure.
Another workaround: right click on the sphere then "Edit feature"
Hope this helps
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Thanks -- that also works. I was using a linked file and I don't seem able to use ' edit feature' with linked files. I can get properties -- but they basically tell me the sphere is blue.
Edit Feature does work in the source file -- but switching files to get a dimension seems unnecessary.
I appreciate both work arounds, but will adda feature request to get more info about spheres with measure.
best,
s
I don't have Edit Feature available in the right click menu and I don't think the sphere is 'linked'. It's just a sphere I created from a point.
Using the Rotate tool in a sketch to create a sphere is usually better than using the primitive Sphere tool.
ETFrench
I'm curious as to why they would be any different? At least in a direct editing mode, anyway. Also, doing it with that method it seems I need to first create a circle, then cut it in half and then do the Rotate as trying it with the circle I get an error about the shape crossing the axis, or something like that. I don't remember the exact wording but I know I worked past it by cutting the circle in half, which itself required adding a point, then a plane of some kind or a line, etc.
The Revolve command requires a closed profile and an axis to revolve around. For a sphere, this means a 180 degree arc and a line connecting the arc endpoints. The line provides the axis and also closes the profile created with the arc.
ETFrench
