I have attached two assembly models. One has free motion along the plane between the two blocks but the motion is restricted between the length of the two slots. The second has restricted motion between the two slot lengths, as the first, but it is also restricted to keep the slots 90 degrees to each other. You were not clear on your desire. I also broke the links between your external components to create F3D files so you can open them directly.
I would suggest you look at the Top View of each model, drag the free component, to understand the different motions.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
