mating imported components
4alanoneill
4alanoneill
I have the hobbyist version of fusion 360.
My existing part models were created in a full version of Inventor which I no longer have access to as I am just recently retired.
I converted my parts (.ipt) to step (.stp) files using the trial version of Inventor 2020.
I imported one file as a new base component or body.
I then imported a second file as a second component or body in an attempt to rebuild the assembly but I cannot figure out how to create any mate from one components surface to the others.
I am beginning to believe it is not possible with the Hobbyist version.
Is there a method to accomplish this?
Will I need to recreate the models in one file?
Thank you for any comment/help/assistance.
Alan
laughingcreek
if they are both components, you can position them with a joint.
if they are still just bodies, then use "create components from bodies" to make them components first.  joints don't work on bodies.
4alanoneill
thank you for the quick reply.
Now I just have to have to figure out what that means.
Alan
laughingcreek
file \export and .f3d your model and post to forum.  someone will most likely make a video for you
4alanoneill
had my supper
came back and watched a short video
it all makes sense now... and works!
thank you
