material removal - beginner
richasS6H6Q
richasS6H6Q
Basic but I am stuck. I want to have the vertical columns with the hole not extend to the bottom. So I need to cut from the inside bottom surface up to some point. Some how this eludes me...
Rich
TheCADWhisperer
@richasS6H6Q
richasS6H6Q
attached, thanks
TheCADWhisperer
@richasS6H6Q
I am leaving my computer for several hours - but check back, I will show you how you can dramatically simplify your techniques.
Observe that there are unresolved issues highlighted in your Timeline. (Run the command Ctrl b or CMD b on Mac).
See the Attached file last sketch and feature.
richasS6H6Q
I see what you did there with that sketch, in the center and then extrude/cut I imagine. Thank you. I am adapting someone else's design and I suspect the errors come from my modifications and how I did them...
Rich
Thanks again
TheCADWhisperer
@richasS6H6Q
Step through the Timeline of this one.
Double click on sketch dimensions to edit distances.
richasS6H6Q
Thank you! Very minimal steps.
Rich
