Mass reduction
Mass reduction
Mass reduction
Hello
If you had to reduce the mass of a body like this one what technique would you apply without reducing its strength?
Accepted solutions (3)
g-andresen
Completely without changes to the load-bearing capacity will hardly work.
For example, instead of a solid material, you can use a tube with a corresponding wall thickness or a lighter material with comparable properties.
Also, it could be a case for generative design.
günther
TheCADWhisperer
@Anonymous
Simulation>Shape Optimization
laughingcreek
open channels.  increase web width in the direction need to achieve needed load bearing capabilities.
t_kuraa
Try to run Generative Design
