Mass Calculations Differ?
jamesf2SRYX
jamesf2SRYX
Hi All.
I am trying to get a reliable value for total mass of this design.  If i window select around the entire assembly and then select properties, it gives me one result.  If i select the assembly in the browser, right at the top, right click and properties, it gives me a completely different result.  I have a feeling that maybe there are removed or hidden components that are being shown in the browser view.
Anyone got any ideas?
Many thanks
James
dsouzasujay
Hi @jamesf2SRYX ,
Thanks for the question. The difference you’re seeing is often due to hidden bodies/components that still get counted in one method but not the other.
Could you please try the following:
  • Show all Bodies and Components in the browser.
Recheck the mass using both methods and see if the values match.
If the results are still different, feel free to share the design file (*.f3d/*.f3z) so we can take a closer look.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
jamesf2SRYX
Hi
Many thanks for that. I will do as you suggest and test the results. I'll
share the file as well.
I cant do it now as im at work, but will do so later this evening.
Thanks again,
James
jamesf2SRYX
Hi
I tried what you said and your correct, the mass is now the same on both selections.  Its obviously showing hidden items, so I suppose the correct way to do this is to either remove items, or use the window select method.  Anyway, thanks for your assistance.
