Mesaj 1 / 2
- Yeni Olarak İşaretle
- Sık Kullanılan
- Takip Et
- Sessize al
- RSS Akışını Takip Et
- Vurgula
- Yazdır
- Bildir
I am struggling to animate a joint manually (i.e., grabbing the component with the cursor, and exercising the joint movement). In the file attached, the LegAndFlange component is joined as a revolute joint to the Hub component, but when I grab the LegAndFlange component to exercise the revolute joint motion, the LegAndFlange component simply moves away (without rotating) from the other components. What am I doing wrong? Do I need to "ground" the Hub?
Çözüldü! Çözüme gidin.
