Manage Extension
Manage Extension
Lennart_Losjo
Message 1 of 10
Manage Extension
Lennart_Losjo
Hi. Are there any thoughts about creating a section for Fusion Manage?
There is a lack of information on the workflows.
The online course for Manage Extension have only 4 videos, and none of them is on how to create a new change order and the workflow after that.
Cheers Lennart
Senior Product Specialist
Fusion 360, Inventor.
Replies (9)
Message 2 of 10
jhackney1972
Is the the Forum you are looking for?
John Hackney, Retired
Message 3 of 10
Lennart_Losjo
Thanks, man. Not even Autodesk provided med this link. Thanks again.
Message 4 of 10
Lennart_Losjo
Well, when i looked in the forum, its most about fusion manage, not the fusion manage extension for Fusion 360.
Message 5 of 10
Lennart_Losjo
No one have any input regarding this?
Message 6 of 10
kgilham
Hi @Lennart_Losjo,
Are these the videos you are referring to in your original post? https://help.autodesk.com/view/fusion360/ENU/courses/AP-MANAGE-EXT-LIVE-EXAMPLE
The third video walks through the release process in the Fusion context but is there something missing that you are needing some help with?  If you have any questions feel free to just use this board and you can ping me with an @ and I should be either able to help or maybe point you to a resource that could help.
Kyle Gilham
Customer Advocacy Manager
Message 7 of 10
Lennart_Losjo
Hi.
Thank you for your answer.
Yes, i have looked at all four videos.
What I am missing is the opposite workflow.
Make a change order to do a revision of an item.
I have tried the following.
Created a CO.
I Chose the Item I want to change in the affected items.
Put a life cycle in.
Changed the state to WIP.
Opened the file in the item.
Made some changes in the part.
Saved the part.
Sent the item to quick-release.
The preview is wrong and when I open the file again, the changes I made are not there.
I have succeeded sometimes but not others.
Message 8 of 10
kgilham
Hi @Lennart_Losjo
From your description you are running into a limitation that we don't have a warning for yet.  The issue is, if you have a CO open and the part or assembly is in the WIP state you must save with a Milestone in order for those changes to be captured in the CO.
We realize that there is no obvious way for the user to know this and are working on ways to fix this in the future.  Hopefully this gets you up and running.  If you this doesn't fix the issue let me know.
Kyle Gilham
Message 9 of 10
Lennart_Losjo
Thanks, man, @kgilham  I will try this workflow.
Another thing with the CO, I cant somehow assign the CO to a specific person in the team?
When the CO is changed to work, I don't see the CO in my outstanding work.
My CO looks like this.
ANd my dashboard.
Message 10 of 10
kgilham
Hi @Lennart_Losjo,
It could be a couple things.  In your first picture it looks like it still needs to be saved.  If you have already done that and it's still not showing up, try selecting that small refresh symbol.  I've highlighted it in the picture below.
I've sometimes had to wait for a minute to let the back end get caught up with the changes I just made but if it takes longer than it may be something else.
Kyle Gilham
