Making Multiple Solid Bodies from Surface
Hi All,
So I'm Trying to make a bike seat for a project I'm working on, and I want it to have it look like a classic Brooks saddle.  I've already created a solid body for the leather (after modifying the surface to what I wanted and thickening it), but now I'd like to use the organic surface of my solid body to create the metal substructure that holds the leather in place.  I basically want to just extrude off of the surface, but I'm not really used to surface modeling at all.  Any help would be greatly appreciated.  Thanks!
What I've made so far (sorry the leather grain looks kind of terrible)
And the underside
And this is the metal frame I want to make.  I'll be OK with the rails if I can get the metal supports created.
innovatenate
Autodesk Support
Autodesk Support
Hi Adam,
I took a crack at a workflow that you might use to create the metal substructure under the seat. I've made a video that you can review to see it in action.
A short summary of the actions taken in the video are:
I converted the sculpt surface to a B-Rep
I created an zero offset body
I un-stitched the body into separate surface bodies
Deleted some surfaces bodies to clean up
I used some planes to split faces
Deleted the unwanted faces
Finally, I thickened the remaining faces
http://screencast.com/t/2RBWDbjibJn
There are other ways to achieve this result as well. Hope this helps!
Nathan Chandler
Principal Specialist
deyop
Here is one approach.  Convert the TSpline to a solid body when you are satisfied with the shape.  You can then create a sketch with the paths that you would want to move parallel to the form.  Use Split Face to project the curves from the sketch to the face.  That can be used as a path to sweep solid bodies or additional TSpline forms.  Here is an illustration with the concept.
Fantastic help!  Thanks to both of you.  I'll post an updated photo when it's finished.
