Making a negative
Making a negative
GMDCNC
Making a negative
GMDCNC
Is there a (relatively) easy way of making a negative (essentially using a body or component to cut) of an object? Not trying to make a mold; trying to make a knob that can press fit on a McMaster-Carr wingnut.
I know I can just make a knob that will fit on a regular nut, and make a polygon to cut it out. I'm doing this because I want to, not because I need to.
GMDCNC
Disregard. I figured out why combine wasn't working for me.
TrippyLighting
If you've figured out the problem please mark this therad as "solution provided" or whatever it was called. That way we can move on to other users in need of help 😉
Thanks in advance!
