Making a groove/slot in 1st component for 2nd component which have complex movement and shape
Message 1 of 12
First of all SORRY FOR MY ENGLISH. Let me explain the problem: for example i need to rotate cylinder from 90 deg to 0 deg with cutting a some box to make a groove for moving cylinder:01fus.png
02fus.pngIts very easy to do! BUT how to make a groove path for rotating object which have complex shape? For example like this: 03fus.png04fus.png
Of course some of fusion experts can say something like: "you need to make a shape's max points projections, rotate this projections around axis, make a sweep or a loft, cut box with that sweep,...blablabla,...but what if this object with complex shape also rotating in 2 directions while "grooving" the box? or sliding while rotating? (i even cant create a picture for this situation....cuz im new)
Even by math calculations its very hard to make a "cutting path" for complex movement of complex shape. So my question is "how to cut a one component by second, which have COMPLEX shape and COMPLEX movement? probably by simulating joints movement? by some other fusion-360 instruments?".
Please help!
Replies (11)
Message 2 of 12
etfrench
You could try this:
  1. Create a motion link between the two joints controlling the motion.
  2. Drive one of the joints in very small increments.
  3. Use Combine/Cut at each increment. (You may need to create create a new component each time and also save the tools.)
ETFrench
Message 3 of 12
TheCADWhisperer
Is there a silhouette projection tool somewhere in Fusion?
@Anonymous
Can you File>Export and then Attach your complicated *.f3d example here for experimentation?
Message 4 of 12
This is some kind of solution BUT unfortunatly this solution can give me only "rough approximation" of true continious grooving path. I need to find a way to get something much more closer to true groove path instead of creating 1000 increments
Message 5 of 12
Yes of course, there you go: 2 files.
1) Complex shape and "easy" movement
2) Complex shape and complex movement
Message 6 of 12
etfrench
The first one is just a simple revolve after projecting the body to a sketch:
I would use the API to create a script to do the complex one.
ETFrench
Message 7 of 12
Probably the API script is the only thing which can help (but i dont know how to write it cuz im not a programmer)
Revolving projections DOESNT solve the problem for any complex shape( only for some sort of).
For example lets edit previous body - it will have same projection but .....:
Sorry for such ugly example but be sure - there is an infinite ways to create a really complex forms, which's groove path is different from path generating by revolving any of it's projections.
Message 8 of 12
TheCADWhisperer
I made a mistake somewhere and have to go back and find it - but I assume that something like the Attached is what you are after...
Message 9 of 12
@TheCADWhispereryour first idea about cutting a body with small increments is correct, but for getting true groove path the increment should be an "infinite small", like "dx"
But what about projections - as i wrote before making a true groove path is not only about revolving some projection of body4353637.png
By the way, @TheCADWhisperer do you know where i can suggest an idea for instrument to fusion360 developers? I suppose adding this standart tool to make grooving paths for mooving components will be a really cool !! instead of making a hemorrhoid for users to solve this problem individually every time
Message 10 of 12
TheCADWhisperer
@Anonymous wrote:
@TheCADWhispereryour first idea about cutting a body with small increments is correct,....
I did not make any such suggestion?
Message 11 of 12
TheCADWhisperer
In my previous example I attempted to Sweep-Boolean Cut one solid body with another solid body, but I accidently introduced an offset in my sweep path.  (Image from Autodesk Inventor Professional.)
Message 12 of 12
Screenshot from Autodesk Inventor Professional looks pretty correctly about what i want to get (at least for simple movement but complex shape). Fusion 360 doesnt have body sweep, only sketch/face sweep
