MacMaster Carr not usable for European users...
macmanpb
macmanpb
In Europe all metrics are in millimeters, meters and so on. MacMaster Carr have less metrics like that.
I have searched for bearings. All bearings are provided in Inch. Not usable!
Other stuff has no cad models provided. What is that, a compromise?
Smiley Wink
etfrench
You can always find a European manufacture that provides 3d models in their online catalog 🙂
McMaster-Carr seems to have quite a few metric bearings: http://www.mcmaster.com/#standard-ball-and-roller-bearings/=wfual1
ETFrench
daniel_lyall
yes mc masters do not sells to many places outside usa but the parts are usefull, just not the part numbers hoppfuly more companys will jump in as well there are other places over your way that supply cad data.
theres nothing you can do about it if you ask them you wont like the reply they feed ya some bs and prity much tall you to F off I tryed
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
JamieGilchrist
hi macmanpb,
estimating by your user name you are running on a mac?  There is a solution for Windows, a plug-in from Cadenas available at the Autodesk Exchange site.  Unfortonately Cadenas has only made a windows compatible plug-in.
I have used the site solidcomponents.com, there are lots of suppliers from the EU in there.  The down side is they aggregate from multiple suppliers and each supplier usually requires an account set up to access their database of components.
that said, yes the McMaster-Carr was put in as a first step for giving users accross all OS platforms access to standard components within Fusion.  Since the majority of Fusion users are currently in the US we felt this was a reasonable place to start.  We are in the process of outlining a broader strategy for content and content access for all Fusion users, but in the mean time will have to rely on availability from outside vendors to sastify this need.
The availability of content is a big issue to tackle and we want to do it right for Fuision users, would apreciate getting some insight from you what you would like or expect to have with regard to access of standard components within Fusion.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
nrdyper
@JamieGilchrist wrote:
... We are in the process of outlining a broader strategy for content and content access for all Fusion users...
That was 7 years ago. At what strategy have you arrived? Can you point to an article or documentation?
